Sep 9th, 2024, 11:24pm
Pages: 1 2 3
question about charge pump in PLL (Read 19501 times)
lonemy
hefei anhui china
Nov 17th, 2011, 5:03am
Dear All:
I have a question about the stability of charge pump in PLL.
the ckt is like attachment fig.1. if the charge pump sink current to the LPF, there two loops in ckt, like fig.2. we can see that loop1 is a negative feedback loop and loop2 is positive. my question is: at low frequency, the impedance of LPF is larger than ro2, so the positive feedback is stronger than negative feedback, then the ckt is not stable, but in real case, this ckt works normally, could anyone tell me where my mistake is ?
thank you~
View Profile lonemy   IP Logged
raja.cedt
Re: question about charge pump in PLL
Reply #1 - Nov 17th, 2011, 5:37am
hello,
yes you are correct, you have to design in such a way that -ve loopgain > +ve feedback. I also doubt how to make -ve loop strong here but i wanted to tell you that due to higher impedance of the loopfilter +ve feedback wont be stronger because it is parallel with pmos transisters. But i have never seen this kind of CP!!
Raj.
buddypoor
Bremen, Germany
Reply #2 - Nov 17th, 2011, 5:42am
Lonemy,
I don't think it is correct in this case to apply the small signal loop gain model. Rather, the circuit is designed as a switch to provide pulses.
raja.cedt
Reply #3 - Nov 17th, 2011, 5:51am
hello buddypoor,
you are correct, but i guess it is a bias ckt for charge pump (he has to seperate loopfilter from this ckt).
I have a doubt here, forget about chargepump action,here how to make -ve feedback stronger?
raj.
lonemy
hefei anhui china
Reply #4 - Nov 17th, 2011, 10:30pm
Dear Raja:
        attachment is the paper which introduce this kind of CP.
lonemy
hefei anhui china
Reply #5 - Nov 17th, 2011, 10:31pm
buddypoor wrote on Nov 17th, 2011, 5:42am:
Lonemy,
Dear Sir:
       as you told, how can I check the stability of this kind of ckt? thanks
Reply #6 - Nov 18th, 2011, 9:28am
You may want to also take a look at classic H-bridge driver charge pumps as well.
The shown device does not maintain the voltage points of the switches, (while both open and shut) which will lead to some problems as well.
Fixed one problem and created another.
lunren
Asia
Reply #7 - Dec 4th, 2011, 2:53pm
I think this charge pump is only stable above certain switching frequency. If you want to lower the stable frequency, maybe one way is to change the current mirror ratio.
Lunren
Reply #8 - Dec 5th, 2011, 9:46am
do you need the complexity here?
generally a simple current mirror with ok geometry matching is sufficient.
perfect up-down matching does not get you much other than a publication paper.
RobG
Bozeman, MT
Reply #9 - Dec 5th, 2011, 12:22pm
lonemy wrote on Nov 17th, 2011, 5:03am:
Dear All:
thank you~
The loops do not look like they interact to me - just make sure that loop1 is stable to start with. Loop 2 is positive, but don't look at it's DC gain or small signal critera - pure positive feedback won't make an oscillator - it will just force the output to a rail. Don't worry about it -- the system should be designed around this circuit to prevent it from sticking at a rail.
You need to look at the stability of the *system*. The stability of the system is determined by how long the switch is on and the time constant of the LPF - look at the voltage change at the LFP when the switch is turned on for "dT" seconds. It will change dV = Idc/C*dT. Yes, Idc has a small dependance on the current output (i.e. positive feedback additional current from ro2) but the contribution of ro2 will be small. Even if it is not, you are only worried about the amount of dV, not how you got it. You can do a discrete time analysis and check the stability of the *system* but it doesn't have much to do with the positive feedback in loop2.
The instability you want to avoid is having the LPF jump rail to rail with each update. You prevent that by limiting the maximum charge time and/or making the cap large enough to prevent a large jump. I doubt you will have to worry about this as I'm positive that the settling requirements for the PLL itself will impose far more restrictive conditions to ensure stability.
Reply #10 - Dec 5th, 2011, 3:11pm
Why even use the Op-amp for all the fancy bias?
It will not match perfectly due to non ideal characteristics of the op-amp!
Simple current mirrors, H bridge structure, it works well, and has been used many times
RobG
Bozeman, MT
Reply #11 - Dec 5th, 2011, 4:27pm
I think it would be an order of magnitude increase in signal dependent U/D matching even with opamp imperfections, but as you noted it may not improve the overall performance of the PLL loop. FWIW, the circuit in the paper is slighter different.
rg
lunren
Asia
Reply #12 - Dec 5th, 2011, 6:29pm
loose-electron wrote on Dec 5th, 2011, 3:11pm:
Hi Jerry,
I am interested in this H bridge structure charge pump, can you give me a link or reference?
Lunren
Lunren
Reply #13 - Dec 6th, 2011, 2:15am
ece.wpi.edu/analog/resources/PLLTutorialISSCC2004.pdf
see page 50 of the above
lunren
Asia
Reply #14 - Dec 6th, 2011, 4:56am
Hi Jerry,
Thanks a lot.
Lunren
Pages: 1 2 3
