Aug 1st, 2024, 11:33am
LC tank Q factor (Read 6770 times)
summi
LC tank Q factor
Nov 19th, 2011, 1:16pm
Dear forum,
for an LC tank always Q dominated by Inductor Q, because it is lower than varactor Q. Corect me if any thing wrong. And is this domination always true or any exceptions?
Br,
Summi.
rfidea
Europe
Re: LC tank Q factor
Reply #1 - Nov 19th, 2011, 2:02pm
That is usually true but not always. If you have an low loss air coil inductor and a lossy varactor it is maybe the varactor that is dominating the Q.
Reply #2 - Nov 19th, 2011, 5:58pm
unique to the components available.
Low Q inductors are common in semiconductors, but there are exceptions. (special dielectrics, and low resistance metal structures)
Need to consider all the elements used and what their non ideal characteristics are.
raja.cedt
Reply #3 - Nov 20th, 2011, 3:15am
hello,
I donno about other meterial passives like dielctric and loss air coil. But in IC level passives IND Q increases with frequency and Varactor Q decreases with Frequency, so for a given area and technology there is frequency below that inductor Q dominates and above varactor Q dominates.
Raj.
Reply #4 - Nov 21st, 2011, 2:14pm
generally true, yes, but if you get into certain SOI stuff (thinking sapphire here) there are some situations where the parasitics are very different.
raja.cedt
Reply #5 - Nov 22nd, 2011, 2:04am
hello looselectron,
i didn't get u..Normally paracitic caps Q will be higher (infact inf), so if you have paracitics across the tank so overal Q will be dominated i guess.
Sorry please explain if you find any mistake
Raj.
singh
Reply #6 - Nov 22nd, 2011, 8:56am
summi wrote on Nov 19th, 2011, 1:16pm:
Dear forum,
Br,
Summi.
if u use offchip inductor, then its Q will be higher than varactor..generally to minimize losses, off chip inductor is preferred
raja.cedt
Reply #7 - Nov 22nd, 2011, 10:27am
hello singh,
you are correct but at low frequency, when you go to high frequency or IC level Q will be increased.
Raj.
Reply #8 - Nov 29th, 2011, 3:59pm
raja.cedt wrote on Nov 22nd, 2011, 2:04am:
hello looselectron,
Raj.
Raj - the message I am trying to give here is that the conditions are unique for the foundry process.
Parasitics are different, resistance of metal layers are different. Both affect inductor Q in a big way.
So, the question has to be looked at within the limitations of a particular foundry process.
