Aug 15th, 2024, 10:32am
Pulse generator in verilog-A (Read 3385 times)
ssp
Nov 20th, 2011, 5:46pm
I'm new to verilog-A and I'm trying to generate an output pulse of 0V at every falling edge of my input pulse signal (1.8V to 0V) in Spectre. Unfortunetly, using the following code, my output pulse seems to be generated at a rising edge :
`include "constants.vams"
`include "disciplines.vams"
module allo(in,out);
parameter real td = 3n;   // width of pulse
parameter real tt = 0n;    // output transition time (s)
   output out;
   input in;
   voltage in, out;
   real Vout, tend;
   analog begin
     @(cross(V(in), -1)) begin
	 Vout = 0;
	 tend = $abstime + td;
     @(timer(tend))
	 Vout = 1.8;
	   V(out) <+ transition(Vout, td, tt);
My resulting signals :
ssp
Re: Pulse generator in verilog-A
Reply #1 - Nov 20th, 2011, 9:02pm
To be more clear, this is the signal train I want to have :
[img][/img]
How can I obtain that output ?
Thank you for your help,
ssp
Forum Administrator
YaBB Administrator
Reply #2 - Nov 20th, 2011, 11:24pm
Your model looks okay to me. Perhaps the problem is elsewhere. Please provide enough information so we can replicate your simulation.
ssp
Reply #3 - Nov 21st, 2011, 7:15am
Hi Ken,
the problem is that my code doesn't generate the output pulse as I wich it did. It seems that the @cross function is not working well, or perhaps the code I made have a mistake in it that I can't detect...I don't know if this can help but my input signal comes from a dynamic comparator working with an intern clock of 12ns period. I want to use the output pulse as a reset signal for a PMOS transistor.
ssp
Reply #4 - Nov 21st, 2011, 7:18am
Also, my simulation was made using Spectre Cadence with a transient analysis.
boe
Reply #5 - Nov 21st, 2011, 7:37am
Your cross event tests for negative crossing with threshold 0. This is probably not what you intended.
- B O E
ssp
Reply #6 - Nov 21st, 2011, 7:48am
Hi Boe,
yes, your right, that's the problem. Is there a way I can set the threshold voltage to 1.6V in the @cross function ? If not, is there a simple code to detect falling edge of a signal with min. 0V and max. 1.8V ?
Thanks!
ssp
Reply #7 - Nov 21st, 2011, 9:24am
By reading verilog-ams guide more carefully, I only need to add V(in)-1 in the cross function to make it work:
@(cross(V(in)-1,-1))
Reply #8 - Nov 22nd, 2011, 10:38am
ssp wrote on Nov 21st, 2011, 9:24am:
Always a good idea!
ssp
Reply #9 - Nov 23rd, 2011, 3:06pm
Hi guys,
I still don't exactly get the result I'm expecting with this code:
parameter real td = 10n;   // width of pulse
parameter real t1 = 0n;
   output out;
   input in;
   voltage in, out;
   real Vout, tend,rst;
analog begin
	@ (initial_step or cross(V(in)-1, -1)) begin
	   // @ (cross(V(in)-1, -1)) begin
		 Vout = 0;
		 tend = $abstime + td;//return simulation time + td
	  @(timer(tend))
		 Vout = 1.8;
I want to detect the first falling edge on the Vin signal (time 65.24ns), while my code only detects the second falling edge at time 75.21 ns. Why is that ? Is there a way I can fix my code to detect the first falling edge ?
Thanks for your help,
ssp
Forum Administrator
YaBB Administrator
Reply #10 - Nov 24th, 2011, 1:07am
Never put a contribution statement or a transition function inside an @ block.
boe
Reply #11 - Nov 24th, 2011, 4:42am
ssp wrote on Nov 23rd, 2011, 3:06pm:
You do detect the edge @ 65.24 ns; because of the 10 ns delay you specified (td in transition filter), the output changes @ 75.24.
BTW, Ken: The contribution statement is not inside the @ block, the code is just poorly indented.
- B O E
ssp
Reply #12 - Nov 24th, 2011, 7:25am
wow, yes, I guess I was I tired when I wrote that..I add 2 delays with the transition.
I was wondering, at what rate does the @cross function samples signals ?
Forum Administrator
YaBB Administrator
Reply #13 - Nov 24th, 2011, 1:24pm
Argh. Normally I will not answer questions from people that cannot be bothered to format their code in a readable fashion. I should have stuck with that policy here.
output out;
input in;
voltage in, out;
analog begin
    @(initial_step or cross(V(in)-1, -1)) begin
	  Vout = 0;
    @(timer(tend))
	  Vout = 1.8;
Improperly indented code is largely unreadable, leading to confusion and mistakes, and making it hard for people to help you. Before asking someone to look at your code, you should indent it properly. It only took me a few seconds to do it, and in doing it you often find the problem yourself.
boe
Reply #14 - Nov 25th, 2011, 4:56am
ssp wrote on Nov 24th, 2011, 7:25am:
See documentation: Cadence Verilog-A language reference, section cross-Event.
- B O E
