Jul 17th, 2024, 6:30pm
How to differentiate in 2nd order (Read 7572 times)
aistudy
Dec 02nd, 2011, 7:31am
i'm converting Agilent ADS SDD's with functionality for FET RF-components to Verilog-A.
I've a problem to convert a weighted function for using with Verilog-A.
The SDD-Part and resulting function looks as follows:
F[6,0]=-_i6
F[6,6]=(_v6*_v2)
H[6]=rth_/(1+j*2*PI*freq*tauD)+rthf/(1+j*2*PI*freq*tauDF)
--> 0 = -_i6 + (_v6*_v2) * (rth_/(1+j*2*PI*freq*tauD) + rthf/(1+j*2*PI*freq*tauDF))
I've converted the it in Verilog-A to following function:
I(tor6) <+ (rthf + rth_) * (_v6*_v2) + (rthf * tauD + rth_*tauDF) * ddt(_v6*_v2) - (tauD+tauDF) * ddt(_i6) - (tauD+tauDF) * ddt(ddt(_i6));
The simulation results of the whole component varies about two to four decimals from original in S-Parameter simulation.
I must convert the function which depends on the frequency to the time domain. I think this could be the problem, because I need for this calculation a diffential 2nd order. I solved this by using ddt(ddt(x)). I this correct?
Is there any possibility to use frequency dependend functions in Verilog-A and if yes can someone tell me how?
If I want to give freq-value from ADS as parameter I get the error message:
"Improper frequency dependence in `SDD_va' parameters"
How can I solve this problem?
aistudy
Re: How to differentiate in 2nd order
Reply #1 - Dec 5th, 2011, 1:17pm
I haven't fully comprehended what you're trying to do, but I have concerns about ddt(ddt(x)) in an expression.  I would try adding an internal node.
electrical ddtnode;
I(ddtnode) <+ V(ddtnode) + ddt(_i6);
I(tor6) <+ ... * ddt(V(ddtnode));
aistudy
Reply #2 - Dec 5th, 2011, 2:30pm
I must use the following differential equation for calculating the current _i6:
at the moment I'm using the following statement in Verilog to assign the current:
But it seems that there's something wrong, or Verilog don't accept the  ddt(ddt(_i6)). The DC-Simulation is ok, but the S-Parameters varies two decimals behind the decimal point.
You mean I should do something like this?
I(ddtnode) <+ ddt(_i6);
I(tor6) <+ (rthf + rth_) * (_v6*_v2) + (rthf * tauD + rth_*tauDF) * ddt(_v6*_v2) - (tauD+tauDF) * ddt(_i6) - (tauD+tauDF) * ddt(I(ddtnode))
The original equation is in the frequency domain, at the moment I convert it to the time domain for Verilog. Is there any possibility to use directly the equation in frequency domain and give the "freq" value from Agilent ADS to the Verilog module as parameter?
Thanks a lot
aistudy
boe
Reply #3 - Dec 6th, 2011, 4:46am
aistudy wrote on Dec 5th, 2011, 2:30pm:
Yes, I think that's what Geoffrey meant. Some simulators do not support nested ddt's.
There are the laplace filters, which allow implementation of (constant) transfer functions.
- B O E
aistudy
Reply #4 - Dec 6th, 2011, 9:52am
what do you mean with "constant", in my case I want to use it with the given frequency value from Agilent ADS. Is this possible?
Can you tell me which laplace function I have to use? I'm at the moment a amateur but I want to learn. I've tested to use laplace_nd but I've no reason why it doesn't work. This is the case because I  convert the equation to time domain.
Thanks a lot
aistudy
boe
Reply #5 - Dec 8th, 2011, 3:50am
Hi aistudy,
aistudy wrote on Dec 6th, 2011, 9:52am:
what do you mean with "constant", ...
Time-invariant.
You choose the Laplace filter function depending on the form of the transfer function you want to use - as you can see in the L(anguage)R(eference)M(anual).
- B O E
aistudy
Reply #6 - Dec 8th, 2011, 9:45am
Hello boe,
sorry, but I do not know which laplace-function I have to choose for the following equation:
This equation should result in an assignment of Current to _i6 and is in frequency domain. Can you help me a little bit to understand?
I'm also not sure if it is constant, because the value "freq" comes from Agilent ADS and will be changed during simulation.
Thanks a lot
aistudy
boe
Reply #7 - Dec 12th, 2011, 12:16pm
aistudy,
your transfer function seems to be
rth_/(1+s*tauD)+rthf/(1+s*tauDF).
It should not be too hard to convert that into a quotient of two polynomials.
- B O E
aistudy
Reply #8 - Dec 12th, 2011, 2:37pm
Hi boe,
I transfered it into
_i6 = (rthf + rth_) * (_v6*_v2) + (rthf * tauD + rth_*tauDF) * ddt(_v6*_v2) - (tauD+tauDF) * ddt(_i6) - (tauD+tauDF) * ddt(ddt(_i6));
I think this should be the correct transformation. Can you help me a little bit, because I'm not so good in system theory. I've only learned the bases.
aistudy
Reply #9 - Dec 14th, 2011, 8:46am
BOE meant you should convert rth_/(1+s*tauD)+rthf/(1+s*tauDF)
into something like
A (1 - s/z1)(1 - s/z2) / ( (1 - s/p1)(1 - s/p2) )
and now z1,z2 are the zeros and p1,p2 are the poles that would go into the laplace_zp (zero-pole) function.
