Sep 17th, 2024, 7:26am
Req example of pulldown command in VerilogA (Read 7884 times)
animotion
Dec 02nd, 2011, 10:04am
Forum Users,
I need to model a pulldown function in VerilogA.
When the cntrl signal is high, this closes a mosfet switch and the signal of interest is then pulled to ground.  This is the circuitry that I must model.
I am aware that there is a pulldown function in VerilogA (correct me if I am wrong).  However, I do not know how to use the function.
Can someone please provide an example here that shows how to use it?
animotion
Re: Req example of pulldown command in VerilogA
Reply #1 - Dec 5th, 2011, 1:21pm
pulldowns are mentioned in the Verilog-AMS LRM, but I don't think of them as being part of Verilog-A.
The syntax is:
pulldown [pulldown_strength] pull_gate_instance { , pull_gate_instance };
pull_gate_instance ::= [ name_of_gate_instance ] ( output_terminal )
pulldown_strength ::=
( strength0 , strength1 )
| ( strength1 , strength0 )
| ( strength0 )
So:
pulldown pd1 (out);
would instantiate a pulldown named "pd1" on the node "out"
boe
Reply #2 - Dec 6th, 2011, 4:52am
Geoffrey,
the pulldown of Verilog-AMS is digital, so it won't work in Verilog-A.
I suggest a resistor to GND.
- B O E
animotion
Reply #3 - Dec 6th, 2011, 8:34am
BOE
Thank you for the reply.
How do I write the resistor to ground to model the circuitry that I describe?
animotion
animotion
Reply #4 - Dec 6th, 2011, 8:47am
Geoffrey & BOE
The VerilogA LRM lists pulldown as a VerilogA HDL keyword in the Appendix but it does not give an example of is use.
The code that Geoffery gives may apply to VerilogA too.  I will try this with the cntrl on the mosfet tested in an if statement.
Paul
animotion
Reply #5 - Dec 6th, 2011, 10:37am
The pulldown as described is not working for me in VerilogA.
I am willing to try out the resistor to ground if either of you could show me the code.
boe
Reply #6 - Dec 6th, 2011, 10:57am
You could try something like:
V(out) <+ I(out)*transition( (V(cntrl)>VDD/2) ? 1/Ron : 1/Roff, 1n);
- B O E
