pcardoso73
Portugal
I thought before posting. Maybe I wasn't clear enough in my questions.
1 - In the transient simulation you have liberal, moderate and conservative. We know that conservative simulation takes longer. The goal here is to set some parameters, in order to decrease simulation time maintaining conservative transient simulation.
2 - At this point (close to tape-out) the oscillator cannot have an imposed initial consition, it should start by itself. For this you need a transient to do a PSS, otherwise you don't have an inital condition for your PSS (please refer to the Spectre RF manual - Chapter 6). Thus only one transient simulation should be done in order to save lots of time.
3 - By Jitter in weak inversion I mean Phase-noise/jitter in subthreshold region. Despite the MOSFET behaving "like a BJT" in weak inversion, once both use the same exponential law, except for a factor of "n" in the MOS equation (the square law is no longer valid in this region). As the flicker noise is up-converted that will affect phase-noise/jitter quite a lot. So the designer should minize 1/f noise. As the BJT has much better behavior regarding 1/f noise than MOS, I thought of using the MOS in weak inversion to have a "similar" behavior as a BJT. But the phenomena that cause flicker noise in BJTs and in MOS are different, and as SNR decreases significantly, the weak inversion is not the way to go. So the aim of the question was, if I would get a better trade-off between power and phase-noise in moderate inversion, than in strong or weak. If the phase-noise performance difference is not significantly different, I shold bias the circuit in Modrate Inversion, once I don't need a large bandwith.
Best regards, Pedro
