Sep 7th, 2024, 11:21pm
Pages: 1 2 3
4-quad current multiplier (Read 5628 times)
Re: 4-quad current multiplier
Reply #15 - Dec 09th, 2011, 5:44pm
If hes at 3nA bias current, I want to see where he is on the bias curve of the device.
The circuit was spaghetti, I agree.
muffassir
Planet Earth
Reply #16 - Dec 10th, 2011, 5:54am
Hi RobG and others ,
Here i am attaching my schematics as drawn in cadence..
Iin1 ,Iin2 are all annotated.Also Ibias=3nA is annotated in the below image.Vdd is set to 0.45V and Vss to -0.45V. Iin1=3nA and Iin2=3nA
The vdd is as inout to the FGMOS vs Id is plotted in the below image u can see the nFG7 to 2 are in this ...See left for counting the FGMOS serial number leftmost is nFG1 and so on to right.
Further for the waves of nFG1/D see below
I have also plotted the drain currents in each transistors verses the input current Iin1 from-3nA to 3nA.
See below image for the Iin1 Vs Id of nFG1.
If you find that the circuit should be manipulated ...please let me know where...???
Also The Iin1 Vs Iout from rightmost corner resistor(see  schematic)..
is plotted.
Hope u all will suggest me some corrections if they are needed.
and let me know so that it will work as multiplier.
The capacitors used at the FGMOS gate inputs is of value 50pF each.
I have tried the circuit by removing the FGMOS capacitors and the associated ckt to make it purely MOS ckt i am getting the same results almost.
View Profile WWW muffassir   IP Logged
RobG
Bozeman, MT
Reply #17 - Dec 10th, 2011, 6:38am
what paper is this based on? I still don't see how it can be anything but a mirror, but I remember a paper by Hassler that also confused me.
You should be able to plot that schematic as a postscript file and then convert it to pdf using ps2pdf. If you attach that instead of the screen shot it might help us as the screen shot is too small.
Vladislav D
The Netherlands
Reply #18 - Dec 10th, 2011, 9:05am
Dude....  are there capacitors Smiley ? the gates are floating.....you d'better to connect the gates to something....
Vladislav D
The Netherlands
Reply #19 - Dec 10th, 2011, 9:07am
Ask yourself what is the voltage at the gates at DC ? There is no DC path for the input current.
I'd suggest to start from a one-gate MOS and to get rid from the current mirrors that copying bias current. Who knows if transistors are in saturation there....and of course, capacitors should not be there
Reply #20 - Dec 10th, 2011, 9:44am
One more time:
Where are you on the bias curves for the transistors in the system?
The reason I am asking this question:
You will learn something if you go answer this question first.
Your DC bias situation needs to be resolved first, if the circuit architecture is not correct the bias will not be correct.
Hint! Hint!
RobG
Bozeman, MT
Reply #21 - Dec 10th, 2011, 7:43pm
Vladislav D wrote on Dec 10th, 2011, 9:05am:
Vlad - The capacitors are floating gate capacitors so that is ok.
I think I'm catching on to how this works. There are two floating gates, so that means the gate voltage of the MOS is the sum of the voltages at the floating gate terminals. Thus Vgs ~ exp(Vgs1+Vgs2) which is what you need to multiplying action. At least I think so...
rg
Vladislav D
The Netherlands
Reply #22 - Dec 11th, 2011, 6:41am
RobG wrote on Dec 10th, 2011, 7:43pm:
OK. I got it. However, there is still a question how does a simulator interpret the potential at the gates at DC.
Muffassir, have u tried transient analysis? Also, I'd still recommend to get rid from current mirrors which copy Ibias for debugging purpose.
Reply #23 - Dec 11th, 2011, 11:38am
You have devices that have no DC bias.
Your definition of DC bias points has not been done with respect to transistor transfer curves.
The static currents are so small that they are probably below the valid bias points of the models, or under the error tolerance settings of the simulator.
Go resolve your DC bias situation first.
muffassir
Planet Earth
Reply #24 - Dec 14th, 2011, 3:58am
RobG wrote on Dec 10th, 2011, 6:38am:
yes u are correct its inspired from the Pual Hassler's paper.
Also i have tried to check the currents through each transistors.I changed the W/L ratios to get the currents in nFG1 and 2 to be Ib using trans analysis..now i am trying to get the Iin2 + Ib in nFG6 and 7 ...i think i am inserting Iin2 at the wrong place as the current is not getting added at the drain of nFG6 .Any suggestion in this regard is much appreciated.
Also i am new to cadence so soon i will upload the pdf file as suggested by you.
Reply #25 - Dec 14th, 2011, 11:32am
Are you familiar with bias curves for transistors or not?
Reply #26 - Dec 14th, 2011, 11:36am
rg
You don't want to use capacitive voltage division unless you have a method of defining the DC operating point.
The ratio floats and does not maintain itself reliably.
RobG
Bozeman, MT
Reply #27 - Dec 14th, 2011, 12:41pm
loose-electron wrote on Dec 14th, 2011, 11:36am:
They use tunneling to put the proper amount of charge on the gate. In theory this will never leak off so it will maintain. The floating cap pretty much acts like a battery in series with the gate. I've seen circuits published where the idea is used to trim opamp offsets or even provide voltage references. I (and others) have a hard time believing that the charge will remain constant over long periods of time, especially for commercial products that can't fail in the field after a year, but Hassler and others swear it will.
Reply #28 - Dec 14th, 2011, 4:36pm
RobG wrote on Dec 14th, 2011, 12:41pm:
They may swear by it, but the rest of the world will swear at it.
Can't seem to get the OP to look at the bias curve location of things.
If you can not set the bias point up properly, everything else is a failure.
Also, currents stated are below default error tolerance of most simulators,
so I think hes looking at nonsense.
I tried.
Anybody got a PDF of this Hassler paper they can send me or post here?
muffassir
Planet Earth
Reply #29 - Dec 15th, 2011, 12:20am
Well below is the paper i am implementing.Usually FGMOS papers are all influenced by the basic work carried out by P.Hasler,C.Driorio,C.Mead at Caltech. As said by RobG they use the tunneling concept. It seems that the RobG is familiar with the FGMOS .
The paper is in 350nm tech..and i am having 180nm tech..
Pages: 1 2 3
