Sep 7th, 2024, 11:20pm
Do I need Tie-high even if nMOS's source/drain isn't rigidly grounded? (Read 513 times)
nandy
Timbuktu
Dec 8th, 2011, 11:15pm
Should I use tie-high cells only for gates of those nmos whose source/drain is connected to another rigid supply (like GND) or should I use it for all nmos whose gate is connected to VDD irrespective of where the source/drain are connected?
« Last Edit: Dec 09th, 2011, 1:27am by nandy »
Re: Do I need Tie-high even if nMOS's source/drain isn't rigidly grounded?
Reply #1 - Dec 9th, 2011, 5:40pm
Substrate tie downs to ground and N-Well tie ups to the power rail should be used used a lot.
More than the minimum required by design rules.
Less latch up problems, less substrate noise problems.
carlgrace
Berkeley, CA
Reply #2 - Dec 15th, 2011, 9:09pm
Are you talking about connecting the gate of a logic cell transistor to VDD or GND?  In that case you should ALWAYS use a tie-hi or tie-lo standard cell.  Otherwise you are Playing With Fire.
If you're talking about substrate and well tie-downs then loose-electron is exactly right.
