![](https://designers-guide.org/forum/avatars/fredflinstone.gif)
Best Design Tool = Capable Designers
Substrate tie downs to ground and N-Well tie ups to the power rail should be used used a lot.
More than the minimum required by design rules.
Less latch up problems, less substrate noise problems.
