Apr 25th, 2024, 9:52pm
need help:ncvlog error (Read 3532 times)
pk9617
Dec 13th, 2011, 4:57am
i was trying to simulate a verilog-AMS,  but i occured error. (using version: ius_v5.7_qsr1)
ncvlog(64): 05.70-s001: (c) Copyright 1995-2006 Cadence Design Systems, Inc.
ncvlog: *E,AMSN64: Verilog-AMS not supported in 64-bit mode.
i went through the /32bit directory... the files of ncvlog,nclaunch ...
did not existed. I dont know why. i run the executable "ncvlog" in directory "install_dir/tools/bin", but it is still 64-bit mode.
is there anything wrong in my installation of ius?
how can i resolve this problem? Sad
thanks
boe
Re: need help:ncvlog error
Reply #1 - Dec 13th, 2011, 7:07am
pk9617,
IUS 5.7 is very old. Try updating to a recent version.
Also check if option -64bit is somewhere set as default.
- B O E
Joeyao Chou
Reply #2 - Nov 23rd, 2015, 7:06am
I think the programmer of this tool must misunderstand the Cadence environment variable CDS_AUTO_64BIT.
In order to run 32 bit ncvlog, you need to unset this variable, i.e.
unsetenv  CDS_AUTO_64BIT
BTW, set it to NONE or any other value does NOT work.
Just unset this variable.
