Jul 17th, 2024, 5:16am
peak power calculation (Read 3085 times)
watson822
Taiwan
Dec 19th, 2011, 4:57am
please help me calculate peak power in 802.11g 6Mbps 26dBm output, thanks
watson822
Taiwan
Re: peak power calculation
Reply #1 - Dec 20th, 2011, 10:27pm
sorry, is peak voltage, not peak power, anybody know how to calculate? please kindly help~~
Reply #2 - Dec 21st, 2011, 10:17am
have you read the specification for the standard?
aaron_do
Reply #3 - Dec 21st, 2011, 4:57pm
First of all, peak voltage depends on the impedance level. Usually there is some VSWR specification for the standard. For instance, the transceiver may need to work for a VSWR of 5:1, and not explode with a VSWR of 10:1. So for a 50-ohm system with a VSWR of 10:1, you are potentially looking at 500 ohms.
Power = V2/R
You should also take into account the peak-average power ratio. It depends on the modulation scheme. For a sine wave it is 3 dB. But I'm guessing that for 802.11g it's higher.
Lastly, the peak voltage that you are actually going to get in your circuit can be highly dependent on the implementation. It depends on things like the harmonic content of the signal, and also whether or not there are any transmission lines between the components.
Hope I haven't missed anything out, and feel free to correct me anywhere...
cheers,
Aaron
weber8722
Reply #4 - Jan 2nd, 2012, 1:44am
All looks right. Here is a nice detailed article  :):
http://www.elliottlabs.com/documents/OFDM.pdf
For peak-voltage calculation you also have to be aware of peak-to-average power ratio. For a pure sine wave the peak power averaged over one RF period is constant, but modern modulation schemes such as OFDM have some amplitude modulation.
Bye Stephan
Reply #5 - Jan 2nd, 2012, 12:46pm
Sometimes ytou will find peak vs. average is a function of the modulation.
So its usually a good idea to check the specification.
