Jul 17th, 2024, 7:34am
A basic Question Regarding impact of spurs on jitter (Read 3262 times)
raja.cedt
Dec 27th, 2011, 2:24am
hello every one,
I have a basic Question regarding impact of spur on integrated rms jitter. When we multiply every individual block phase noise with respective transfer function and add all we get total pll phase noise curve, but we don't get spurs in this process but in the real time we get spurs at the reference frequency and those spurs add some thing to area, so while modeling how to consider this impact?
Raj.
Re: A basic Question Regarding impact of spurs on jitter
Reply #1 - Dec 28th, 2011, 10:45am
Depends on what is in your model I would think.
One comment first: Jitter or Phase noise? Two different ways of looking at the same thing.
You need to model your feedthrough
and feedback paths with more detail in order to
see the second order effects that you are talking about.
What you seem to be describing is a simple hand analysis?
raja.cedt
Reply #2 - Dec 28th, 2011, 11:15am
hello loose electron,
thanks for your responce. I know that jitter and phase noise are related. Could you please tell me how to model reference spurs in the model? I would like to incase of a simple 2nd order loop filter pll.
raj.
Reply #3 - Dec 29th, 2011, 2:19pm
transistor level model or behavioral?
If its at the transistor level, I would get rid of everything except phase detector, charge pump and filter.
(faster to simulate)
set up a simulation where you do an FFT of the VCO control voltage (Filter output)
with everything else behavioral.
raja.cedt
Reply #4 - Dec 30th, 2011, 7:06am
hello loose-electron,
what is the use of estimating Control voltage FFT? i know it gives more or less phase noise scaled by Kvco am i correct?
Any how thanks i will try implement this.
raj.
Reply #5 - Dec 30th, 2011, 3:37pm
You were looking for spurs due to the reference frequency feeding through to the VCO output.
What I just described should look at that effect and just that effect.
Thus the suggestion.
