Sep 8th, 2024, 11:26am
How to find the process parameters (Read 1607 times)
sri.sagar
Dec 22nd, 2011, 10:59pm
Hi everyone, is there any way to find µncox and µpcox value in cadence, if so , do let me know, thanks in advance
raja.cedt
Re: How to find the process parameters
Reply #1 - Dec 23rd, 2011, 5:02am
hello,
are you a college grad?, you can find but whats the use of finding those parameters. becaz you don't know what the vgs-vth power in the id equation. Any please refer alpha power modeling by sakurai, you get some knowledge in this regard.
RAJ.
Reply #2 - Dec 23rd, 2011, 4:50pm
sri.sagar wrote on Dec 22nd, 2011, 10:59pm:
It is buried in the transisor models in some cases.
(depends on the transistor models)
Another method is to use a set of transistor bias curves
and reverse engineer them out of there.
As a general rule, these don't get used too much
except as an academic illustration.
sri.sagar
Reply #3 - Dec 26th, 2011, 3:11am
thanks for the reply , I am doing my internship in analog design and i did reverse engineering considering CS stage as an exapmle and i got Mncox = 132u and Mpcox=32u for  90nm technology. i am not sure whether it's correct or not, if anybody knows the process parameters (Mncox and Mpcox) values for a particular technology/any other technology please let me know, so that i can compare my values.
and one more question is that , will the above parametes increases or decreases as the technology shrinks ?
raja.cedt
Reply #4 - Dec 26th, 2011, 3:33am
hello,
most of the times it increases (from theory point of view).
One thing i want suggest is if you want to continue in circuit design better start use gm/id method rather than struggling with finding about process parameters.
you can refer ee214 lectures notes by Boris murmon
raj.
RobG
Bozeman, MT
Reply #5 - Dec 26th, 2011, 8:11am
sri.sagar wrote on Dec 26th, 2011, 3:11am:
Small devices physical are so dependent on width and length that I would suggest a simulation where you sweep width for a few lengths to "measure" whatever parameter you are interested in. You should be able to also find some information on this in the process documentation.
The last 180nm process I worked in also had μnCox ≈ 4*μpCox. According to the textbooks it should be about 3x so I'd be very interested in why this is.
rg
sri.sagar
Reply #6 - Dec 26th, 2011, 9:25pm
Here is the way which i had followed,  and correct me if I am wrong as  am a newbie to this analog field
Steps to calculate µncox value in cadence
1). Consider a CS stage
Assume gain Av = 5v/v, RD = 10k, ID = 100µA, µncox = 150µ
                         Gain AV=gm RD
gm = AV / RD
gm = 5/10k = 0.5mƱ
But
gm = sqrt (2 µncox (W/L) n ID)
 (W/L) n = 8.33 ≈ 10
So set W=10µ and L=1µ
After simulation, the gain(new) AV = 5.2 ≈ 5 (initially assumed)
gm(new) = 541.3 µ ≈ 0.5m (initially assumed) and   ID(new) = 111µ
Based on gm (new), ID (new) and (W/L) n (old), we can calculate µncox as
µncox = gm2/ (2(W/L) n ID)
µncox=132µ
The procedure remains same for µpcox and i got the value as
µpcox=32µ
Reply #7 - Dec 27th, 2011, 12:41am
Hi sri.gagar,
Have you plot I-V curve of nmos and pmos transistors? Are you sure those MOS's follow square law rule for that 90nm CMOS technology? If NOT, do the parameters μncox and μpcox you derived fit all MOS widths/lengths in your design? You'd better simulate Gm/Id suggested by Raj and sweep width for a few length suggested by RobG. Please open the following link for some references about Gm/Id.
http://www.designers-guide.org/Forum/YaBB.pl?num=1299031733/4#4
Yawei
raja.cedt
Reply #8 - Dec 27th, 2011, 2:13am
hello sri.sagar,
in your post you have calculated gm by normal square law which is true only above 180nm (some rough number), which is gives very wrong results with 90nm and below. I strongly encourage you to proceed with gm/id, if you are still interested to do by this kind of calculation fist find the power of the Vgs-Vth in the current expression, for this refer
http://dit.upc.es/lpdntt/biblio/BREUS/SAK90a.pdf
raj.
sri.sagar
Reply #9 - Dec 27th, 2011, 10:26pm
thank you, it helped me a lot
