Sep 8th, 2024, 1:21pm
average noise power (Read 1435 times)
singh
average noise power
Dec 23rd, 2011, 10:38am
i have a transfer function which is multiplied with noise voltage density transfer function (flicker+white noise curve) and i get resulting data from that.
So in order to calculate avergae noise power, do i need to take Root mean square of all the values or root sum square of all the values?
Please help me on this
raja.cedt
Re: average noise power
Reply #1 - Dec 23rd, 2011, 11:34am
hello,
finally you have to find rms value of the output. but already you have output psd, so just find sum and take square root.
thanks,
raj.
singh
Reply #2 - Dec 23rd, 2011, 12:48pm
raja.cedt wrote on Dec 23rd, 2011, 11:34am:
hello,
thanks,
raj.
thanks
for noise voltage density i use
eVN2 = eFN2/freq + eWN2;
eVN  = sqrt(eVN2)
suppose my transfer function
   save_tf_values(j) = variable1;
   save_output_noise(j) = variable1 * eVN;
these eVN values i multiply with my transfer function for each frequency and get data.. eVN is not squared.. so i think i need i need to take rms as shown below?
rms = sqrt(mean(save_output_noise.^2))
please suggest whether this correct?
raja.cedt
Reply #3 - Dec 23rd, 2011, 2:14pm
yes, sounds correct. But why u r doing this.
singh
Reply #4 - Dec 26th, 2011, 1:04pm
i have two different transfer functions and i want to see which one has more noise power..
thanx for ur suggestions
aaron_do
Reply #5 - Dec 26th, 2011, 5:23pm
not sure if I'm missing something here, but why did you divide EFN2 by freq?
thanks,
Aaron
singh
Reply #6 - Dec 27th, 2011, 2:33am
aaron_do wrote on Dec 26th, 2011, 5:23pm:
thanks,
Aaron
efn is flicker noise voltage at 1Hz and the flicker noise gives 1/freq behaviour ... i just took general formula to calculate total noise due to flicker and white noise
HdrChopper
Reply #7 - Dec 30th, 2011, 4:10am
If intereseted in average noise power, you need to integrate the resulting noise psd at the output.
Best
Tosei
Keep it simple
