xuedashun
I am using spectre to run a simulation. The testbench is very simiple and has a voltage source, a resistor and a diode. The diode has symbol view and veriloga view.
But I have an error in the simulation log file: " ERROR: Netlister: unable to descend into any of the views defined in the view list "spectre cmos_sch cmos.sch schematic vedriloga ahds" for instance Idiode in cell....."
I don't understand why it happens. It seems netlister can not find the veriloga view for the diode, but it's in my library. I remember specter supports veriloga model. (If I use config view for the testbench, it should be ok. I just want to use spectre only to simulate it)
Could you give me some suggestion? Thank you!!
