danmc
Boston
I seem to be doing something silly but can't see what's wrong. I wanted to model a schmidt trigger input inverter in verilog-A where the output stage is modeled as a pair of resistors. Resistor #1 goes from the power supply pin to the output and resistor #2 goes from the output to ground. The value of the resistors is controlled by an internal state variable.
In the following code, if I drive A1 with a square wave input, I can plot the state variable S1 and see it following the input (but inverted) but the output (Y1) is not moving at all. It is stuck at VDD.
The reason I wanted to drive my output this way is it a) keeps the output coupled to the supplies at all times so if I have wiggles on VDD while my output is high, my output follows and
b) if I'm driving a capacitive load then I'll pull currents from VDD and VSS appropriately.
Any ideas?
Thanks -Dan
electrical A1, Y1, VDD, VSS; input A1, VDD, VSS; output Y1; parameter real high_percent=0.6; parameter real low_percent=0.4; parameter real rhigh=10e6; parameter real rlow=10.0; parameter real cout=10p;
integer S1; analog begin
// when we are above the high threshold, set the state to 0. // do I need an @cross possibly with a $discontinuity(0)? @(above( V(A1,VSS) - high_percent*V(VDD,VSS))) begin S1 = 0; end // when we are below the low threshold, set the state to 1. @(above( low_percent*V(VDD,VSS) - V(A1,VSS))) begin S1 = 1; end // put in the resistors V(Y1,VDD) <+ I(Y1,VDD)*transition( S1 ? rlow : rhigh, 1n); V(Y1,VSS) <+ I(Y1,VSS)*transition( S1 ? rhigh : rlow, 1n); // and some capacitance to ground I(Y1, VSS) <+ cout*ddt(V(Y1,VSS)); end // analog
