Aug 15th, 2024, 3:47pm
problem with output stage model (Read 1276 times)
danmc
Boston
Jan 24th, 2012, 11:24am
I seem to be doing something silly but can't see what's wrong.  I wanted to model a schmidt trigger input inverter in verilog-A where the output stage is modeled as a pair of resistors.  Resistor #1 goes from the power supply pin to the output and resistor #2 goes from the output to ground.  The value of the resistors is controlled by an internal state variable.
In the following code, if I drive A1 with a square wave input, I can plot the state variable S1 and see it following the input (but inverted) but the output (Y1) is not moving at all.  It is stuck at VDD.
The reason I wanted to drive my output this way is it
a)  keeps the output coupled to the supplies at all times so if I have wiggles on VDD while my output is high, my output follows and
b) if I'm driving a capacitive load then I'll pull currents from VDD and VSS appropriately.
Any ideas?
-Dan
electrical A1, Y1, VDD, VSS;
input A1, VDD, VSS;
output Y1;
parameter real high_percent=0.6;
parameter real low_percent=0.4;
parameter real rhigh=10e6;
parameter real rlow=10.0;
parameter real cout=10p;
integer S1;
analog begin
    // when we are above the high threshold, set the state to 0.
   // do I need an @cross possibly with a $discontinuity(0)?
     @(above( V(A1,VSS) - high_percent*V(VDD,VSS))) begin
      S1 = 0;
    // when we are below the low threshold, set the state to 1.
     @(above( low_percent*V(VDD,VSS) - V(A1,VSS))) begin
      S1 = 1;
    // put in the resistors
     V(Y1,VDD) <+ I(Y1,VDD)*transition( S1 ? rlow : rhigh, 1n);
     V(Y1,VSS) <+ I(Y1,VSS)*transition( S1 ? rhigh : rlow, 1n);
    // and some capacitance to ground
     I(Y1, VSS) <+ cout*ddt(V(Y1,VSS));
end // analog
Re: problem with output stage model
Reply #1 - Jan 24th, 2012, 11:50am
Hi, Dan -
I'm suspicious about this line:
and the one after it.
Are you allowed to multiply transition by anything?
Are you sure I(Y1,VDD) is non-zero?
danmc
Boston
Reply #2 - Jan 24th, 2012, 1:45pm
I'm not sure that I can multiply transition anything.  I've tried without the transition filter.  As for the current level, I'm basically trying to model a pair of resistors. One to VDD and one to VSS.  I've also tried creating an internal electrical like
electrical VS1;
     V(VS1) <+ transition(S1, 1n);
     V(Y1,VDD) <+ I(Y1,VDD)*(rlow*V(VS1)  + rhigh*(1.0 - V(VS1)));
     V(Y1,VSS) <+ I(Y1,VSS)*(rhigh*V(VS1) + rlow*(1.0 - V(VS1)));
Do I need to not list both V and I on the left side of <+ ?
Forum Administrator
YaBB Administrator
Reply #3 - Jan 24th, 2012, 2:52pm
There should be no problem implementing the resistors by multiplying the current by a transition function. I do this kind of thing all the time.
I suspect the problem you are having is caused by the fact that you do not specify a transition time for your transition functions. Perhaps what you meant to specify was:
transition( S1 ? rlow : rhigh, 0, 1n);
The second argument is the delay, the third argument is the transition time.
danmc
Boston
Reply #4 - Jan 24th, 2012, 6:26pm
Ken,
Yes, I meant to specify 0 delay and then 1n for the transition time.  Unfortunately it didn't help.
-Dan
Forum Administrator
YaBB Administrator
Reply #5 - Jan 25th, 2012, 8:53am
The model looks okay to me. The next step is to debug it. I would start by plotting VDD and VSS as a sanity check. Then  modify the model to save the output of the transition functions to local variables and plot them. You might also save the pull up and pull down currents into local variables and plot them.
