Aug 15th, 2024, 6:25pm
Pages: 1 2
voltage leakage in VCO's switching capacitor (Read 11589 times)
boe
Re: voltage leakage in VCO's switching capacitor
Reply #15 - Feb 06th, 2012, 1:05am
YCY,
YCY wrote on Feb 3rd, 2012, 4:45pm:
I probed the gate current and found it is exactly equal to the drain current but has opposite sign.
Does this mean the current flowing out of the Minus terminal of the Cap (I(/C2/Minus)) all goes to the gate terminal?
Yes, it does.
Quote:
Hi loose-electron
I agree with you. There must be something wrong in simulator setup.
However I cannot find where.
What are your settings for gmin and cmin? Are they negligible compared to the impedances of your circuit elemens?
- B O E
YCY
Reply #16 - Feb 6th, 2012, 6:12pm
boe wrote on Feb 6th, 2012, 1:05am:
YCY,
Yes, it does.
Quote:
Hi loose-electron
- B O E
Hi, B O E
I set gmin from 1e-12 to 1e-15, and it does affects the results.
The smaller the gmin, the longer the discharging time.
As for cmin, it seems to have no influence on the simulation results.
I tried to set cmin to 0, 0.1f, and 1f.
BTW, now I think nrk1 is right.
The reverse-biased diode between drain/bulk is the main cause that discharges VD to 0V.
Because if I connect bulk to 1.2V, VD will be charged to 1.2V rather than 0V.
But I still do not know why the current flowing out of the cap is not equal to that flowing into the NMOS.
YCY
nrk1
Reply #17 - Feb 6th, 2012, 6:28pm
Strange. Not sure if D/S/B terminal currents which are probed include currents in the drain/source diodes. Some experiments to check:
1. Increase AD/PD of the MOS and see if the rate or droop increases.
2. Connect an identical MOS transistor with drain and source to the present circuit's drain, and gate to the present circuit's gate. Check if the rate of droop increases(because of extra diodes).
YCY wrote on Feb 5th, 2012, 9:35pm:
nrk1 wrote on Feb 4th, 2012, 6:02am:
YCY,
Is the nMOS bulk connected to source or 0V? ...
Hi, nrk1
Yes the bulk is connected to 0V.
But the bulk current is near 0A, thus I guess it not the main cause.
YCY
Reply #18 - Feb 6th, 2012, 7:31pm
nrk1 wrote on Feb 6th, 2012, 6:28pm:
YCY,
Hi, nrk1
Hi nrk1,
I think your previous post (#11) is right, the reverse-biased diode between D/B results in the leakage of VD.
Thanks for your suggestion.
YCY
boe
Reply #19 - Feb 7th, 2012, 10:15am
YCY wrote on Feb 6th, 2012, 7:31pm:
Hi nrk1,
YCY
If you connect the bulk of the nMOS to 1.2V, you will forward-bias the drain-bulk diode if VD < 1.2V.
- B O E
Pages: 1 2
