boe wrote on Feb 6th, 2012, 1:05am:YCY,
YCY wrote on Feb 3rd, 2012, 4:45pm:...
I probed the gate current and found it is exactly equal to the drain current but has opposite sign.
Does this mean the current flowing out of the Minus terminal of the Cap (I(/C2/Minus)) all goes to the gate terminal?
Yes, it does.
Quote:Hi loose-electron
I agree with you. There must be something wrong in simulator setup.
However I cannot find where.
What are your settings for gmin and cmin? Are they negligible compared to the impedances of your circuit elemens?
- B O E
Hi, B O E
I set gmin from 1e-12 to 1e-15, and it does affects the results.
The smaller the gmin, the longer the discharging time.
As for cmin, it seems to have no influence on the simulation results.
I tried to set cmin to 0, 0.1f, and 1f.
BTW, now I think nrk1 is right.
The reverse-biased diode between drain/bulk is the main cause that discharges VD to 0V.
Because if I connect bulk to 1.2V, VD will be charged to 1.2V rather than 0V.
But I still do not know why the current flowing out of the cap is not equal to that flowing into the NMOS.
YCY
