Sep 11th, 2024, 10:18pm
limit cycle (Read 3139 times)
raja.cedt
limit cycle
Feb 05th, 2012, 9:06am
hello,
can any one please tell me about limit cycle, and what it's significance...at least give me some reference or some thing.
Raj.
boe
Re: limit cycle
Reply #1 - Feb 7th, 2012, 10:32am
Raj,
a (stable) limit cycle is a kind of oscillation. An important example is an oscillation of a recursive digital filter in fixed-point arithmetic stimulated and sustained by the rounding error.
Which context interests you?
- B O E
raja.cedt
Re: limit cycle
Reply #2 - Feb 7th, 2012, 10:47am
hello boe,
thanks for the reply, i am getting this word very repetitively when i am studying discrete system  stability and about jitter. So could you please  explain what is limit cycle, i am guessing it is a root-locus of some thing.
raj.
HdrChopper
Re: limit cycle
Reply #3 - Feb 7th, 2012, 8:30pm
Hi Raja,
This is more or less what I remember...
Typically in non-linear systems, the solutions to differential equations representing such systems have singularities around which the trajectory of such solution (in the plane defined by the state variables) cycle around such point.
As boe suggested they represent oscillations conditions that can be reached depending on the initial conditions of your non-linear system: a typical limit cycle is the switching of a buck converter when analyzed as a non-linear system, or idle tones on a sigma delta converter when also analyzed as non-linear feedback system.
Best
Tosei
Keep it simple
boe
Re: limit cycle
Reply #4 - Feb 8th, 2012, 4:34am
Raja,
Tosei's explanation seems OK to me; however, the difference to instability of linear systems is that they are oscillations of fixed amplitude.
- B O E
RobG
Bozeman, MT
Re: limit cycle
Reply #5 - Feb 26th, 2012, 5:14pm
Raja - The idle tones in a delta sigma modulator can be thought of as limit cycles, although I'm not sure if they are the same thing as what you are researching. See page 41-45 of Schreier/Temes's book.
rg
