Jul 3rd, 2025, 1:47am
Simulated and calculated value discrepancies in simple parallel RLC circuit. (Read 4347 times)
VINAY RAO
Mar 04th, 2012, 10:10pm
Hello all,
I tried to simulate parallel RLC circuit with values R= 550 Ohm, L = 712pH and C=821fF. All these components are ideal which are taken from anologlib in cadence. For the above given values, resonant frequency is calculated to be 41.3GHz (Formula : 1 over root (L *C)). But when I simulated and checked with s parameter analysis, resonant frequency came around 6.6GHz !! I attached schematic setup and as well as the result which is showing ZM. Why I am getting so much difference between calculated and simulated values?
Vinay Rao.
VINAY RAO
Re: Simulated and calculated value discrepancies in simple parallel RLC circuit.
Reply #1 - Mar 4th, 2012, 10:13pm
SOLVEDVINAY RAO wrote on Mar 4th, 2012, 10:10pm:
Sorry. I did calculation mistake. Results are fine.
Vinay Rao.
