Jul 16th, 2024, 12:32pm
How to do random simulation on parameters defined in a verilog-A model? (Read 4654 times)
manodipan
Mar 07th, 2012, 2:10am
Hi All,
I want to random simulations on some parameters defined in my verilog-A model. Can you give some suggestions?
Re: How to do random simulation on parameters defined in a verilog-A model?
Reply #1 - Mar 7th, 2012, 6:42am
I can't give any suggestions without a better idea of what you're trying to do.
Are you trying to do something with $random or $rdist in the Verilog-A model, or do you just want to pass some random values to parameters of your module (so you would just put the appropriate GAUSS calls in the netlist)?
manodipan
Reply #2 - Mar 8th, 2012, 9:11pm
Passing on a list of parametrs is ok,but if i don't want to do then how to apply randomness to any parameter let's say random width variation and i want to know random distribution of the output current....
Reply #3 - Mar 9th, 2012, 6:48am
Like I said: your two options are to pass GAUSS as a parameter value, or within the module to use one of the $rdist_ functions to add a variation to the width that's actually used in the current computation.  Be careful, though, that you don't get a different random value for each timepoint if you use the latter approach.
