Helge Stenström wrote on Jan 27th, 2009, 5:17am:There is such function in Cadence rfLib, but it is not ideal.
What model do you mean "rfLib/shifter" or "rfLib/shifter_splitter" ?
Helge Stenström wrote on Jan 27th, 2009, 5:17am:Is it possible to model a phase splitter with constant phase difference and constant gain in both paths?
If you don't care numerical costs ehausted in simulation, you can build model to approximate ideal phase shifter.
For example, there are three implementations.
(1) Use ideal Hilbert-Transformer by FIR realization.
(2) Use complex BPF of high orders enough for realizing wide band.
For example, use ideal integrator.
Of course, you can use multi cascaded poly phase filter for realizing complex BPF.
(3) multiply exp(-j*omega0) and filter this result with LPF or BPF and then multiply exp(+j*omega0), here you can get analytical signal of original signal.
Anyway it must be always big burden in simulation if you model wide band phase shifter.
