rajdeep
Hi All,
Thanks for your reply guys. Extracted simulation is undoubtedly a good idea. Although I think the difference is because of the PCB layout, rather than the differences in the layout of the chip, it's worth trying! I have done some hand calculation depending on the layout and put them in schematic. But, yes cant be as accurate as the extracted one. Point on sidewall-cap is interesting.
Raja, I can do that, but unfortunately cannot do an all layer change, only metal edits. This is a usmd package where the center ones are accessed via extra vias, whereas the one at the edge are accessed directly. So the inductance could be different. But yes, whether it is the trace inductance, or also some mutual inductance are troubling, or the parasitic resistors, I am not 100% sure, but my (influenced by the popular gospels in our grp) hunch it's the slight increase of distributed inductance without much of real evidence really!
Just out of interest, why do you say that making dominant pole based on output pole would help here? In dropout when the pass-tr enters linear region, the o/p impedance drops quite a lot, and in which case can screw up the compensation even more, isnt it? Having said that, the overall loop gain drops, so that may help stabilizing the system.
Thanks! Rajdeep
