Frank Wiedmann
Examine the Spectre logfiles to see if you are using the same Spectre version in both cases. If not, configure your Cadence 5 setup to use the same Spectre version as your Cadence 6 setup.
If you are using the same Spectre version and still have problems, compare the netlists generated by Cadence 5 and Cadence 6, especially the line for the vcvs in question.
