despap
Problem Statement: VCC = 1.8 - 2.0V Process details: VT ~ 500mV nominal Ft > 6GHz Ibias varies +/-10% over and above Poly-Resistor variation.
I have a two single-ended fully differential signals,each 50mVPP, on common mode of VCC,max frequency of 1.5GHz. This needs to be converted to CMOS levels. ( 0-VCC swing) with minimal affect on Duty cycle at the output.
Any suggestions please..
Thanks, desPap
