Aug 1st, 2024, 3:26pm
Opamp polaritiy (Read 1281 times)
raja.cedt
Opamp polaritiy
Mar 03rd, 2012, 12:32pm
hello all,
i am reading a patent on charge pump for low spur PLL, find the attached fig.  but the basic problem is during M1,M2 turn on opamp has -ve feedback but how about feedback polarity when M5,M6 on.
Here i assume tail current source is realized by nmos whose gate is driven by opamp.
raj.
Vladislav D
The Netherlands
Re: Opamp polaritiy
Reply #1 - Mar 3rd, 2012, 1:09pm
There are two feedback loops here: negative and positive. To make the circuit stable, loop gain of the positive loop should be smaller. This is achieved by the divider, formed by C1 and R1.
Looks like, at high frequency, the loopgain of the negative loop increases...
raja.cedt
Re: Opamp polaritiy
Reply #2 - Mar 4th, 2012, 12:56am
hello,
think about dc always, then ac.
Raj.
Re: Opamp polaritiy
Reply #3 - Mar 4th, 2012, 5:22pm
The op-amp does not see the high frequency switching.
Interesting configuration - You are changing
the charge pump current
to maintain common mode voltage.
Most of the time I have seen the opamp
maintain the voltage of the other side of the H-Bridge
Re: Opamp polaritiy
Reply #4 - Mar 17th, 2012, 7:48am
Hi raj.
I don't know what's the purpose of that charge pump scheme. But I think One node, like Vx, probably is set to a common mode voltage. So you remove one loop.
Yawei
A Kumar R
India
Re: Opamp polaritiy
Reply #5 - Mar 20th, 2012, 12:25am
hi raja,
if M1 & M2 are turned on op-amp is in negative feedback configuration, if otherwise, the op-amp is in positive feedback configuration...
Anil
raja.cedt
Re: Opamp polaritiy
Reply #6 - Mar 20th, 2012, 2:04am
hello anil,
whats the difference between my first post and your post?
