Aug 1st, 2024, 5:12pm
basics Question (Read 1626 times)
raja.cedt
basics Question
Mar 16th, 2012, 2:39pm
hello,
this is some purely theory based and graduate level question. If there any LC filter and if i apply some dc voltage at the input, the peak-voltage at the cap is 2 times the input voltage. I have derived and got ans, but is there any way understand intuitively without doing math.
thanks,
raj.
RobG
Bozeman, MT
Re: basics Question
Reply #1 - Mar 17th, 2012, 9:15am
Do you mean that you are applying a stepped input?
raja.cedt
Re: basics Question
Reply #2 - Mar 17th, 2012, 11:09am
yes....
RobG
Bozeman, MT
Re: basics Question
Reply #3 - Mar 17th, 2012, 5:13pm
I'm rusty, but I get the answer to be a sine wave with amplitude Vstep/sqrt(LC). Where do you come up with the number 2?
HdrChopper
Re: basics Question
Reply #4 - Mar 17th, 2012, 8:34pm
A step input will create an oscillation whose amplitude will depend on the values of L and C around whatever DC level the voltage step has. thus does not have to be 2x
Keep it simple
raja.cedt
Re: basics Question
Reply #5 - Mar 18th, 2012, 1:51am
hello all,
i donno how you guys solved, but i have used normal circuit theory and i got it is v(1-cos(w*t)), so it's peak is 2*v, in fact this is quite common result in transmission lines also.
Raj.
RobG
Bozeman, MT
Re: basics Question
Reply #6 - Mar 18th, 2012, 9:20am
raja.cedt wrote on Mar 18th, 2012, 1:51am:
hello all,
Oh hell, I did the impulse response, not step response. I now get the same answer as you. I guess chopper and I may have to migrate to management soon before we rust completely.
I guess you could say that all of the energy will slosh back and forth between L and C so the minimum energy in each will be zero at some point in time. So that explains the bottom peak being equal to zero. Furthermore, we could say the midpoint (average value) must be v since the average value of the input must equal the average value of the output given the inductive (DC) coupling (and also the steady state solution with a series resistance that goes to zero will be v). Finally, we know the answer is a sinusoid that must start at zero... It is easy to say such things once you know the answer Wink
HdrChopper
Re: basics Question
Reply #7 - Mar 19th, 2012, 7:53am
RobG wrote on Mar 18th, 2012, 9:20am:
[quote author=raja.cedt
I'm working on that already  :P
My mistake was that I always thought of a RLC response, not a purely LC one (do not know why since the question was clear from very beginning! So Raja you were correct!
Keep it simple
Vladislav D
The Netherlands
Re: basics Question
Reply #8 - Mar 19th, 2012, 1:14pm
For the lazy persons (like me) http://www.lccircuits.com/
raja.cedt
Re: basics Question
Reply #9 - Mar 19th, 2012, 3:06pm
hey Vladislav D,
cool man...interesting website. Keep posting this type of websites.
Raj.
