Aug 1st, 2024, 7:20pm
Criteria for choosing a particular W/L to plot gm/id Vs id/(w/l) graph (Read 3404 times)
vinaydreddys
Hyderabad
Mar 16th, 2012, 11:20am
I am trying to understand the sizing approach used in gm/id methodology.
Though I know how to plot gm/id vs id/(w/l) curves for a given transistor, I don't know how to choose a particular W/L for a given process.
ex: TSMC v0.35um             W/L =   50um/2um
      TSMC 90nm                W/L  =   12um/0.5um
and so on...
( The above values are just an example).
So... How to decide the initial W/L values to plot the gm/id Vs id/(w/l) graph.
Vinay
View Profile vinaydreddys   IP Logged
AnalogDE
Re: Criteria for choosing a particular W/L to plot gm/id Vs id/(w/l) graph
Reply #1 - Mar 16th, 2012, 2:25pm
Choose L's that you're most likely to use.  I would start with minimum, 2x minimum, 4x minimum L and so on.  Choice of W doesn't really matter, since it's all normalized (i.e. Id/W).  I would just pick something like W=10um, which should be within the W bounds of the model.
Reply #2 - Mar 16th, 2012, 6:35pm
A different approach -
Start with 2 devices:
1 - min channel length used for switches. (call this device "D")
1- channel length where matching data shows good matching (call this devices "A)
Set the channel W of device "A" to a width that shows good matching.
"A" is now set W/L
"D" is min channel length, and is set to a "W" equal to that of "A"
From here on, your transistor sizing
is totally done by:
NF = #
M = 1, or 2 (for common centroid diff pairs)
Why do this? Now all your transistors are
the same width and makes the layout much easier to do.
vinaydreddys
Hyderabad
Reply #3 - Mar 19th, 2012, 10:34am
Thanks for your valuable inputs.
When i plot with different L s (Lmin, 2x, 4x.. ), I will get different curves, each varying with respect to the other.
So, Which one should I choose, to get W/L s of transistors in the design...?
Say for example, in the design of a 2-stage op-amp, the L for the input transistors is different from that of the L for current mirrors.
(source : MILLER OTA DESIGN USING A DESIGN METHODOLOGY BASED ON THE GM/ID AND EARLY-VOLTAGE CHARACTERISTICS: DESIGN CONSIDERATIONS AND EXPERIMENTAL RESULTS )
So, should I consider two different gm/id Vs id/(w/l) curves... or should I take the average of the curves obtained for different Ls..?
I am confused about the final curve(s), that is taken as reference to proceed with this gm-id approach.
Thanks a lot,
Vinay.
Reply #4 - Mar 19th, 2012, 10:49am
As a general rule you can use a bias curve set to select voltages
and then adjust the desired bias current using changes to W
(or change the NF or M numbers in the method I have outlined)
