Aug 1st, 2024, 3:24pm
ZeroCrossing Detector - 1.5G (Read 2527 times)
despap
Mar 09th, 2012, 8:02pm
Problem Statement:
VCC = 1.8 - 2.0V
Process details: VT ~ 500mV nominal
Ft > 6GHz
Ibias varies +/-10% over and above Poly-Resistor variation.
I have a two single-ended fully differential signals,each 50mVPP, on common mode of VCC,max frequency of 1.5GHz.
This needs to be converted to CMOS levels. ( 0-VCC swing) with minimal affect on Duty cycle at the output.
Any suggestions please..
desPap
Re: ZeroCrossing Detector - 1.5G
Reply #1 - Mar 10th, 2012, 12:42pm
clarify the question
"two single ended fully differential signals"
does not make sense.
is that 4 wires and 2 signals?
is that 2 wires and one signal?
what is the max-F and min-F of the signal?
You give only one.
I think you need an AC coupled, auto zeroed comparator,
but need to understand what you are looking for first.
despap
Reply #2 - Mar 20th, 2012, 2:57am
Two signals:
Both referred to Ground
V1 = 25m*sin(wt)
V2 = 25m*sin(wt+180)
Frequency - 1G to 1.5G
Reply #3 - Mar 20th, 2012, 7:24am
Research:
Differential Current Steering Logic
At those frequencies this is probably where you want to go.
