Jul 31st, 2024, 1:22am
problem with high voltage generator for bootstrap switch (Read 1877 times)
nus_lin
Mar 11th, 2012, 1:07am
dear guys, i assume that the high voltage generator for bootstrap switch in a S/H circuit is quite familiar to most of you.
i am designing one using 65nm tech. but i could not find the breakdown voltage for the source/drain junction, and i am not sure how high it can experience without breakdown. with a 1.2V supply, one of the transistors in the charge-pump part experiences a 2.3-1.2v  swing, is it safe?
Re: problem with high voltage generator for bootstrap switch
Reply #1 - Mar 12th, 2012, 10:09am
nus_lin wrote on Mar 11th, 2012, 1:07am:
The question you are asking is very unique to the particular foundry process.
Find out the limitations from the foundry.
