Jul 17th, 2024, 5:22am
Need help-Does anybody know how to use the GSM antenna to receive the FM signal? (Read 2382 times)
Julie_Zhou
Shanghai
Mar 12th, 2012, 1:37am
Can we use the GSM antenna or other main communication antenna to receive the FM signal? Why? Do you have any other case like this antenna sharing?
Frank Wiedmann
Munich, Germany
Re: Need help-Does anybody know how to use the GSM antenna to receive the FM signal?
Reply #1 - Mar 12th, 2012, 5:01am
Sounds like homework. Hint: consider the frequency of the signals and the antenna properties.
Reply #2 - Mar 12th, 2012, 10:03am
and what are the specifics of frequency?
Julie_Zhou
Shanghai
Reply #3 - Mar 12th, 2012, 6:51pm
Can you explain more clearly? The FM signal  is 78M~120M, the GSM is 800M 1800M. The GSM antenna in the mobile phone can be monopole or PIFA. But I still don't know if we can use the GSM antenna to receive the FM signal?
Reply #4 - Mar 13th, 2012, 10:39am
start by figuring the physical dimensions of each
