Jul 30th, 2024, 11:27pm
closed loop direct vco modulation bandwidth limit (Read 3420 times)
aaron_do
Mar 15th, 2012, 7:50am
hi all,
Can anybody tell me what I'd the maximum signal bandwidth we could have for a closed-loop direct modulation vco? I'm also interested in knowing the main limitations. Basically I want my output phase to track my reference phase, and I want to know how fast can I expect to make my reference phase change...
Aaron
raja.cedt
Re: closed loop direct vco modulation bandwidth limit
Reply #1 - Mar 15th, 2012, 8:19am
loop bandwidth.
raj.
Reply #2 - Mar 15th, 2012, 11:33am
Less than the loop bandwidth.
If you want to maintain phase errors low
you don't want to be near the edge of the loop BW.
aaron_do
Reply #3 - Mar 16th, 2012, 6:32pm
thanks. Yes I suspected the answer was as simple as that. So can anybody tell me what kind of loop bandwidth is possible and roughly how much power consumption it would take?
So I want to actually divide from 2 GHz to some reference frequency (up to me to define), but I need my loop bandwidth to be large. Is it possible to achieve a 100 MHz loop bandwidth? I understand that for an integer-n PLL, the reference frequency is usually around 10* the loop bandwidth. So does that rule out such a simple architecture?
thanks,
Aaron
Reply #4 - Mar 16th, 2012, 6:41pm
Your reference frequency which, in lock,
will end up being seen by the charge pump,
needs to hit a loop filter where they do not
feed through the filter.
So, higher the reference frequency the
higher you can push the loop BW.
