Aug 1st, 2024, 11:25pm
-ve resistance (Read 3251 times)
ali kotb
-ve resistance
Mar 16th, 2012, 6:19pm
how to draw a -ve resistance across cross coupled mosfets?
how to draw the locus diagram of this impedance (imag. vs real)?
thnx
GerryHickman
New York
Re: -ve resistance
Reply #1 - Mar 16th, 2012, 10:27pm
Can you show me your diagram?? so that it is very easy to tell you exactly how to draw it.
ali kotb
Re: -ve resistance
Reply #2 - Mar 17th, 2012, 2:17pm
here is the ct.
i want to find out the value of -ve resistance across c0 cap
and to be able to draw it vs frequency
also i need to draw the locus of this impedance(polar diagram)
thank u
Forum Administrator
YaBB Administrator
Re: -ve resistance
Reply #3 - Mar 17th, 2012, 9:12pm
What is -ve resistance?
Frank Wiedmann
Munich, Germany
Re: -ve resistance
Reply #4 - Mar 18th, 2012, 3:45am
Forum Administrator wrote on Mar 17th, 2012, 9:12pm:
-ve and +ve seem to be relatively common abbreviations for negative and positive, respectively (see http://en.wiktionary.org/wiki/-ve and http://en.wiktionary.org/wiki/%2Bve).
HdrChopper
Re: -ve resistance
Reply #5 - Mar 19th, 2012, 8:00am
ali kotb wrote on Mar 17th, 2012, 2:17pm:
here is the ct.
thank u
- Bias the circuit right at the point where current on both branches are exactly balanced.
- In AC open the circuit at the differential nodes where you want to measure the resistance (drains of x-coupled gates devices)
- Apply a differential AC current of 1A magnitude and measure the voltage magnitude and phase as a difference between both drains of x-coupled gates devices.
That voltage should be the resistance you are looking for.
Keep it simple
