Dec 17th, 2025, 1:15am
Damped harmonic oscillator (Read 4165 times)
Brandon
Mar 19th, 2012, 1:55am
  I am trying to deduce a relationship between the resistance caused by hysteresis and skin effect of a parallel LC circuit and the difference in period measured at two different times while the oscillations are dying out. Below is a link where I describes the phenomena briefly:
http://hyperphysics.phy-astr.gsu.edu/hbase/oscda.html#c2
I have a setup where with a uC I can measure time with a resolution of 100ps. I will try to take measurement at different intervals and by knowing the exact values of inductance and capacitance, I will derive also the q-factor.(by finding ζ)
I also need to figure out how I shall model this resistance. Should it be parallel to the circuit or should I have a single resistance in series with every component? A recommendation of good book on this matter would be really appreciated.
RFICDUDE
Re: Damped harmonic oscillator
Reply #1 - Mar 19th, 2012, 4:40am
There are good papers with additional references located in the Modeling section of this website:
http://www.designers-guide.org/Modeling/
The FracPole suite (used for modeling loss in inductors and capacitors)
http://www.designers-guide.org/Modeling/suite.pdf
Simulation and modeling of nonlinear magnetics
http://www.designers-guide.org/Modeling/mag.pdf
