Jul 17th, 2024, 3:27am
How to verify the quadrature clock signal? (Read 7425 times)
Yutao Liu
Guangzhou, China
Mar 19th, 2012, 7:29am
Hello everyone,
I want to check whether the quadrature clock signal is 90 degree phase shift between each other. The clock is square waveform.
The old way I used is to measure the time difference between rising edge or falling edge of two waveform td, and then use the equation: phase shift =  td/Tclk*360, where Tclk is clock period. However, I suspect the precision of this way, because it is difficult to define the measuring point of td.
So I want to use the correlation critique (1/T)*integral(I(t)*Q(t)*dt), where I(t) and Q(t) are the quadrature clock waveforms. Is this a effective and reliable way?
Welcome any other approaches. Thanks for advanced.
Best
Yutao
raja.cedt
Re: How to verify the quadrature clock signal?
Reply #1 - Mar 19th, 2012, 10:55am
hello,
how you are planing to evaluate the integral, r u using any numerical technique? i guess finding the phase difference is much better and accurate, i donno why you said measuring point Td is different, get the max+min/2 point and find the time corresponding to that.
raj.
RFICDUDE
Reply #2 - Mar 20th, 2012, 6:31pm
The approach that I use is to take the FFT of each of the clock signals then compare the amplitude and phase of the fundamental signals.
This works well for linear circuits that depend on the the quadrature clocks (like mixers), but I do not know if it is adequate for clocking/timing circuits.
Yutao Liu
Guangzhou, China
Reply #3 - Mar 21st, 2012, 6:25am
Hello raja,
Thanks for your suggestion. I also use (max+min)/2 to define the measuring point in my old method. A tiny overshoot in the waveform would deviate (max+min)/2 from the ideal point. So I am afraid of that this would affect the measurement accuracy.
In correlation critique, I am planing to use the calculator in Spectre to do the integral. I(t) and Q(t) are the transient simulation result in Spectre as well. Therefore, I am confused the transient simulation precision has effect on the integral result.
Is my concern unnecessary?
I think the method proposed by RFICDUDE is similar with correlation critique method.
And my quadrature clocks drives a direct up-conversion mixer.
Yutao Liu
Yutao Liu
Guangzhou, China
Reply #4 - Jul 26th, 2012, 8:33am
RFICDUDE wrote on Mar 20th, 2012, 6:31pm:
How do you get the phase of the fundamental signals? Do you run a transient analysis and then DFT to get the real part and image part of the fundamental frequency? This simulation consumes lots of memory and hardly get result in parametric sweep. Is there any better method?
Thanks.
Yutao
RFICDUDE
Reply #5 - Jul 26th, 2012, 5:29pm
Yes, I run transient analysis and obtain the amplitude and phase from a DFT.
I am confused why you are having trouble with memory using transient simulation unless you are saving all nodes and currents in the circuit. If you are running many parametric sweeps then consider saving only the nodes of interest in the circuit.
Other simulation methods consume even more memory to find the steady-state solution you are interested in finding.
Yutao Liu
Guangzhou, China
Reply #6 - Jul 29th, 2012, 1:09am
RFICDUDE wrote on Jul 26th, 2012, 5:29pm:
Thanks for your suggestion! It's a good idea to save only the nodes of interest.
But I have another question on computing the amplitude and phase from the DFT.
I tried to use the "harmonic" function provided by the calculator in spectre to get the level of the fundamental frequency from DFT, but it does not work. And there is the warning that "harmonic" function can not handle "scaler " data from DFT.  So which function in the calculator do you use to compute the amplitude and phase? Or you mark the fundamental frequency by yourself?
Thank you again!
Yutao Liu
RFICDUDE
Reply #7 - Jul 29th, 2012, 5:19am
You can use the "value" function to select a dft result at a particular frequency. The dft function returns complex values (rectangular I think).
Here is an example from the calculator that takes the dft and returns a value at 1GHz.
value(dft(v("vtest" ?result "tran") 50e-9 250e-9 4096 "Rectangular" 1 "default" ) 1e9  ?period nil ?xName "time"  )
Another option is to use the Fourier analysis component that you place in the schematic and it will perform a Fourier analysis of the signal at that node and at the fundamental frequency you specify. This might be the easiest way for you to get the complex harmonics you are looking for.
The fourier analysis schematic elements are in analogLib under category Analysis.
