Jul 31st, 2024, 11:13pm
BGR convergence problem (Read 2868 times)
qiushidaren
I am a lovely
MOSFET!
Chengdu
Mar 21st, 2012, 12:46am
I am simulating a bandgap, but once I put a 500k res on its output, it looks like it can't converge. Could anyone help me solve this issue?
Re: BGR convergence problem
Reply #1 - Mar 22nd, 2012, 11:16am
A bandgap has 2 stable operating point.
Are you familiar with the start up circuit concept?
RobG
Bozeman, MT
Reply #2 - Mar 23rd, 2012, 1:53pm
Jerry brings up a good point. By not converging do you mean that the circuit simulator stops without a solution, or do you mean the circuit simulator gives a result, but the voltage at the output is not the expected ~1.2 V?
If it is the latter, then you need to check your start-up circuit.
rg
qiushidaren
I am a lovely
MOSFET!
Chengdu
Reply #3 - Mar 28th, 2012, 5:54am
RobG wrote on Mar 23rd, 2012, 1:53pm:
rg
I mean the simulator can't give a result, and says no convergence at -40 degree, how to solve this?
-Terry
RobG
Bozeman, MT
Reply #4 - Mar 28th, 2012, 8:01am
It is going to be very difficult to help you without knowing your circuit and test bench.
