RobG wrote on Mar 23rd, 2012, 1:53pm:Jerry brings up a good point. By not converging do you mean that the circuit simulator stops without a solution, or do you mean the circuit simulator gives a result, but the voltage at the output is not the expected ~1.2 V?
If it is the latter, then you need to check your start-up circuit.
rg
I mean the simulator can't give a result, and says no convergence at -40 degree, how to solve this?
-Terry
