Aug 1st, 2024, 7:12am
Best process for weak inversion design EKV model (Read 1648 times)
mixed_signal
Mar 22nd, 2012, 5:59pm
What is the best process for design in weak inversion? I mean which process is most accurately modelled in weak inversion?
Is the EKV model the best for weak inversion? If yes, which processes/technology  are using EKV model for weak inversion and are reliable?
Re: Best process for weak inversion design EKV model
Reply #1 - Mar 22nd, 2012, 6:37pm
If you are trying to do micropower
design, then you want 2 things that I can think of:
- no gate leakage current
- transistors that have been properly modelled in the weak inversion regions and at micro currents.
Large geometry node, lets say 0.18 or even 0.25 micron or larger.
THis is thicker gate oxides and no get leakage due to that.
Transistor models will be what was created back then, you want BSIM 3.2 or newer.
Get foundry data on how the models were created.
Here read this:
http://chipdesignmag.com/display.php?articleId=438&issueId=16
I wrote that on the subject back around 2005
