wave
Hello all - I'm using Spectre to run transients on a relaxation oscillator. Using some normal oscillator tricks (Trapezoidal, InitCond), it starts to oscillate correctly. Then near the END of the Trans simulation I get all sorts of warnings; the usual list of things blowing up, Rel tolerances, try this, try that. ex: Failed test: | Value | > RelTol*Ref + Abstol
...update too large: ....
If I change the Trans sim time and/or accuracy (conserve/moderate/liberal) it does not change. Trying Analog options now, but that's not helping much either.
This is steady state, so nothing SHOULD be changing drastically. This is preventing me from running iterative corner sim loops.
Ideas?
thanks, Wave
