Jul 17th, 2024, 7:18am
Spectre convergence problem near END of a simulation (Read 459 times)
wave
Mar 23rd, 2012, 4:47pm
Hello all - I'm using Spectre to run transients on a relaxation oscillator.
Using some normal oscillator tricks (Trapezoidal, InitCond), it starts to oscillate correctly.
Then near the END of the Trans simulation I get all sorts of warnings; the usual list of things blowing up, Rel tolerances, try this, try that.
ex:  Failed test: | Value | > RelTol*Ref + Abstol
...update too large: ....
If I change the Trans sim time and/or accuracy (conserve/moderate/liberal) it does not change.
Trying Analog options now, but that's not helping much either.
This is steady state, so nothing SHOULD be changing drastically.
This is preventing me from running iterative corner sim loops.
Ideas?
thanks,
Wave
Re: Spectre convergence problem near END of a simulation
Reply #1 - Mar 29th, 2012, 6:40pm
Hi wave,
There are many possible reasons. Probably the model is bad, any inductor inside your circuit, the simulator options ....
Please check the following.
  • Is there anything wrong in the circuit topology?
  • Does the oscillator operate steadily before it has the unconvergence problem?
  • Is there any step in supply?
  • Is there any inductor?
  • Do you set max time step? If NO, please set a reasonable value.
  • Switch to gear2only if the oscillator can start up with gear2only.
Yawei
