Aug 1st, 2024, 1:12am
negative feedback in latch comparator (Read 839 times)
ellarguero
Mar 27th, 2012, 4:10am
hello
i have a problem, i simulate a latch comparator with stb analysis
the schematic is below
i got a negative phase loop which means the feedback is negative, i can't figure out from where comes this negative feedback or is ir an artifact !!!
now i removed the cross coupled pmos pair in the top
like this
and now the feedback is positive,
i am really confused , please help me figuring out what's going on
regards
raja.cedt
Re: negative feedback in latch comparator
Reply #1 - Mar 27th, 2012, 5:05am
hello,
what is the intention of doing behind doing .STB for a latch or what is interested parameter from this simulator?
Any how your Question is valid. What is the exact phase at at 1meg. Due to +ve feedback you +ve phase shift, but due to gds of the pmos and nmos you get _ve phase shift as well. So don expect pure +ve FB.for example if gds is grater than gm then there is -ve feedback rather +ve feedback.
Raj.
ellarguero
Reply #2 - Mar 27th, 2012, 6:32am
hi Raj
the intention is just to understand
i believe the fb is always positive wether gds>gm or not, now if gm<gds the loop gain is not enough to induce latch
i think there is an extra negative feedback du to the common source node (the drain of the current tail). i am trying to figure out how does it work
raja.cedt
Reply #3 - Mar 27th, 2012, 1:35pm
hello,
source node will be at ac ground, so how it will present -ve fb?
