May 17th, 2024, 9:29am
Dout looks HiZ for E2L_2_inhconn (Read 8191 times)
Mar 31st, 2012, 10:11pm
Hi Guy,
It is weird that Dout is always kept HiZ during the simulation.
The code is almost the same as that E2L_2_inhconn in built-in connectLib. I paste the code in the following.
// INCLUDE FILES:
`include "disciplines.vams"
`timescale 1ns / 100ps
connectmodule E2L_2_inhconn (Ain, Dout);
  input Ain; electrical Ain;			   // electrical input
  output Dout; \logic Dout;			     // logic output
// Inherited vdd! and vss!
  electrical
     (* integer inh_conn_prop_name="PVDD";
	  integer inh_conn_def_value="cds_globals.\\vdd! "; *) \vdd! ;
  electrical
     (* integer inh_conn_prop_name="NVSS";
	  integer inh_conn_def_value="cds_globals.\\vss! "; *) \vss! ;
// INSTANCE PARAMETERS:
  parameter real tr=0.2n from (0:1m);		// risetime (for defaults)
  parameter real txdel=4*tr from (0:1m);	   // time midrange til output X
  parameter real ttol_c=tr/4  from (0:1m);	   // time tolerance of crossing
// scaled input/output levels/thresholds (0 maps to Vref, 1 maps to Vsup):
  parameter real vthi=1/1.5 from (0:1);	// frac. for high tresh (def=2/3)
  parameter real vtlo=vthi/2 from (0:vthi);  // frac. for low tresh (def=1/3)
  parameter real vtol=1.0/12 from (0:(vthi-vtlo)/2]; // frac. for vtol
  parameter real vtlox=vtlo+vtol from (vtlo:vthi);  // lo to X state threshold
  parameter real vthix=vthi-vtol from [vtlox:vthi); // hi to X state threshold
// LOCAL VARIABLES:
  reg Dreg;		    // output register
  reg Xin;		     // Tx control registers
  real Kin;		    // input relative to supply range
  real txdig;		  // tx in timescale units
  initial begin
    txdig=txdel/1n;	  // digital delay midlevel to X  (ASSUMES TIMESCALE)
    Dreg=1'b0;		 // initial level
    Xin=0;		     // initially not in X delay region.
// Relative input level (maps input to range of 0=vref, 1=vsup):
  analog  Kin = V(Ain,\vss! )/max(V(\vdd! ,\vss! ),1m);
// Convert analog signal to high/low and X/notX:
  always @(above(Kin-vthi,ttol_c,vtol))
	begin Dreg=1; Xin=0; end			 // analog XtoH
  always @(above(vtlo-Kin,ttol_c,vtol))
	begin Dreg=0; Xin=0; end			 // analog XtoL
  always @(above(vthix-Kin,ttol_c,vtol))
	if (Dreg==1'b1) Xin=1;			   // analog HtoX
  always @(above(Kin-vtlox,ttol_c,vtol))
	if (Dreg==1'b0) Xin=1;			   // analog LtoX
// Wait for txdel before driving output to X:
  always @(posedge(Xin)) begin			 // input changed to X
    #(txdig)						 // wait for X time delay
    if (Xin==1) Dreg=1'bx;			     // goto X if still between
  assign  Dout=Dreg;				     // assign register to output
  always @(Dout) begin
    $display($time, "\t Dout = %1b \n", Dout);
  always @(Dreg) begin
    $display($time, "\t Dreg = %1b \n", Dreg);
The always block @(Dout) and @(Dreg) are for monitoring the toggle of Dout and Dreg. It is curious that Dout is always HiZ although Dreg toggles.
My tools are IC6.1.4.500.10, and MMSIM 11.1.0.249.isr2, and INCISIVE 10.20-s043.
Any comments are appreciated.
Yawei
Re: Dout looks HiZ for E2L_2_inhconn
Reply #1 - Mar 31st, 2012, 10:30pm
The following is part of irun.log.
    errpreset = moderate
    method = traponly
    lteratio = 3.5
    relref = sigglobal
    cmin = 0 F
    gmin = 1 pS
			 1     Dreg = 1
    tran: time = 3.04 ns     (3.04 %), step = 779.9 ps     (780 m%)
			 5     Dreg = 0
    tran: time = 7.559 ns    (7.56 %), step = 133.7 ps     (134 m%)
			 9     Dreg = 1
    tran: time = 12.95 ns    (12.9 %), step = 554.1 ps     (554 m%)
			14     Dreg = 0
    tran: time = 17.67 ns    (17.7 %), step = 554.7 ps     (555 m%)
			18     Dreg = 1
			22     Dreg = 0
    tran: time = 22.73 ns    (22.7 %), step = 480 ps	 (480 m%)
			26     Dreg = 1
    tran: time = 27.68 ns    (27.7 %), step = 772.9 ps     (773 m%)
			30     Dreg = 0
    tran: time = 32.56 ns    (32.6 %), step = 133.6 ps     (134 m%)
			34     Dreg = 1
    tran: time = 37.95 ns    (37.9 %), step = 554.1 ps     (554 m%)
			39     Dreg = 0
    tran: time = 42.67 ns    (42.7 %), step = 554.7 ps     (555 m%)
			43     Dreg = 1
			47     Dreg = 0
boe
Reply #2 - Apr 2nd, 2012, 11:53am
Ywguo,
Is the power supply OK? I remember seeing some very weird behavior without power (although I think it was an L2E-CM).
- B O E
Reply #3 - Apr 8th, 2012, 7:25pm
B O E,
I looked at the simulation again. The supply is OK, otherwise the circuitry  malfunctions. Although Dout in E2L_2_inhconn is HiZ, the succeeding verilog modules (inverters and DFFs) work very well.  :(
Yawei
rsmithuf
Dallas, TX
Reply #4 - May 22nd, 2012, 8:45am
I am also having this problem with the Dout of E2L's staying HiZ although Dreg is toggling. I am using the E2L_0 builtins. Was there any resolution or clue to this?
Thanks!
Reply #5 - May 22nd, 2012, 6:36pm
Hi rsmithuf,
I have not making any progress in this problem.  :(
Yawei
rsmithuf
Dallas, TX
Reply #6 - May 23rd, 2012, 11:20am
So I find that when I probe the E2L's internal signals (Dout, Ain, etc) the Dout is always 'Z'. However, if you look at the cell that this signal is connected to, it is properly resolving to a '0' or '1' depending on the connect rules used.
