Jul 17th, 2024, 3:15am
Linearizing Varactor for LC Oscillator (Read 2243 times)
mtp3
Apr 04th, 2012, 10:32am
Hi!
I am trying to design an LC oscillator (cross coupled NMOS) to oscillate at 2GHz. I have tried some of the commonly used topologies like NMOS(D=S, Bulk=gnd) or PMOS(B=D=S) and PMOS(D=S,B=Vdd).
The problem is when I sweep the varactor control codes(at the DC point of output) for frequency steps/behviour, the resulting frequency does not remain constant for some steps (or code values) rather it jumps back and forth in magnitudes of 2-4MHZ. I am confused as to why this is happening.
It would be great if some could propose a solution to this issue  :-/
raja.cedt
Re: Linearizing Varactor for LC Oscillator
Reply #1 - Apr 5th, 2012, 12:28am
may be useful
Method for a Constant Loop Bandwidth in LC-VCO PLL Frequency Synthesizers
mtp3
Reply #2 - Apr 5th, 2012, 5:01am
Thanks for the reply, will look in to it.
