Jul 17th, 2024, 3:20am
Degrading OOS in low-temperature (Read 1134 times)
Yutao Liu
Guangzhou, China
Apr 05th, 2012, 7:22am
Dear everyone,
I encounter a problem on Origin Offset Suppression with 8PSK modulation. My transmitter is a direct up-conversion topology. Under conditions where temperature is 25 and 75 Celsius degree,  OOS is about -31dB and -35dB respectively. But under low-temperature condition with -20 Celsius degree, OOS degrades to -25dB.
I want to know which factor would dominate OOS with temperature variance, LO leakage/self-mixing or I/Q channel mismatch.
Welcome any suggestion. Thanks!
Best,
Yutao
