Jul 17th, 2024, 5:26am
Improve the AMP for the buffer or vice versa? (Read 2152 times)
henrytqy
Apr 18th, 2012, 10:44pm
Hi guys
I have designed an AMP, and also a buffer for test. But a large Cap is brought by the buffer, which is a problem and limits the BW.
I have come up with an idea, Ind peaking in the last stage of the AMP to overcome it.  Thinking it for twice, I feel the direction is a little wrong, which is that I change my AMP(what I want to design) to adapt the buffer(just for the measurement).
What do you think of my  idea?
Any advice will be greatly appreciated!
Thanks in advance~~~
aaron_do
Re: Improve the AMP for the buffer or vice versa?
Reply #1 - Apr 19th, 2012, 8:10am
I agree...your method sounds wrong. What kind of signal are you trying to measure?
Aaron
Btw, oscilloscopes use 10:1 probes to solve that issue...but maybe there is a better method in your case.
henrytqy
Reply #2 - Apr 22nd, 2012, 7:07am
aaron_do wrote on Apr 19th, 2012, 8:10am:
Aaron
Sorry to reply so late.
My signal is a digital signal before the CDR ckt. Its swing may be as large as 1.5*VDD. But since the instrument has an impedence of 50 ohm, the driver must steer a large current, thus the large W/L.
I don't understand the 10:1 probes in my case, could you please   explain it more clearly.
Thanks a lot~~~
aaron_do
Reply #3 - Apr 22nd, 2012, 5:47pm
If it is a digital signal, why don't you use a string of inverters getting larger towards the end?
