Jul 31st, 2024, 1:21am
Power consumption over nMos (Read 2584 times)
Gil
Apr 25th, 2012, 5:43am
Hi guys (and ladies Wink),
I'm trying to find a way to calculate the power consumption over nMos during a switch (VG turns from 0 to 1 logic).
Lets assume my circuit is made of a DC power supply VDD, connected serially to a resistor R and an nmos transistor.
Calculating the area under the graph ID(VD) (using P=IV) isn't gonna work, because there's no time aspect there..
I thought I could model the transistor as a resistor Rnmos with a capacitor in parallel Cnmos,
this way I can treat Rnmos as the one who's current is ID.
This way after (transistor's) Tau~RC the transistor reaches saturation (the capacitor Cnmos is "disconnected" after T=inf so all the current goes through Rnmos).
Is that a correct observation?
If it is, I'm not sure how can I determine Cnmos.
About the Rnmos - I can use a "zero-order" approximation by determining Rnmos = VDD/Isaturation ,  since after the capacitor charges, the R, Rnmos are serial connected.
Gil.
AnalogDE
Re: Power consumption over nMos
Reply #1 - Apr 25th, 2012, 2:03pm
Pretty complicated to do with only hand calculation...Why not just simulate this?
RobG
Bozeman, MT
Reply #2 - Apr 26th, 2012, 8:02am
AnalogDE wrote on Apr 25th, 2012, 2:03pm:
This seems like a homework problem so I don't want to give the answer, but I think you have the right approach. If you don't have the information to calculate Cnmos you can't include the transient part. Likewise, if you don't have a time period it doesn't make sense to do the transient portion since you don't know how much it contributes to the overall power.
rg
Gil
Reply #3 - Apr 27th, 2012, 9:02am
It's not really a homework assignment, but me trying to figure it out..
I wanna get an intuition about the POWER CONSUMPTION in MOSFET.
I wanted to get a clue about my hunch - if this is a correct way of  thinking..
All that is left is to calculate somehow the R, C, equivalent to the NMOS.
This is where I need someone's advise..  :P
