Jul 31st, 2024, 1:26am
Pages: 1 2
No Peaking with Transient Response with PM of 66 degre (Read 9634 times)
Ricky Chen
Apr 29th, 2012, 1:15pm
I designed a 2-stage Miller compensated CLASS-AB OTA.
The exact schematic is attached.
I found the differential mode Phase margin using Middlebrook method.
I got a PM of 67 degree. The AC response is attached.
When I gave a step input I am NOT seeing any peaking at the 1st OTA output. Actually I should see a slight peaking with 67 PM.
Can anybody tell why there is NO peaking at the output.
The transient response is also attched
Ricky Chen
Re: No Peaking with Transient Response with PM of 66 degre
Reply #1 - Apr 29th, 2012, 1:16pm
The AC response
Ricky Chen
Reply #2 - Apr 29th, 2012, 1:18pm
The Transient response attached
buddypoor
Bremen, Germany
Reply #3 - Apr 29th, 2012, 11:08pm
Hi Ricky,
1.) I suppose the shown ac magnitude respose is the loop gain, correct?
Why didn't you show the phase response?
2.) Are you sure that the loop gain was simulated correctly? According to the slope of the magnitude response at unity gain the phase margin should me much lower (perhaps 45-50 deg).
3.) Does the step response belong to the closed loop circuit?
Ricky Chen
Reply #4 - Apr 29th, 2012, 11:22pm
buddypoor wrote on Apr 29th, 2012, 11:08pm:
Hi Ricky,
1) I have shown the phase response. Just Scroll down the .jpeg file
2)I am assuring you it is correct. I have checked with 2 methods of Middlebrok and both gave the same results
3)Yes it is for the closed loop circuit ( The schematic is the entire circuit and the o/p is take at the o/p of the 1st OTA)
Ricky Chen
Reply #5 - Apr 29th, 2012, 11:36pm
Ricky Chen wrote on Apr 29th, 2012, 11:22pm:
Hi Ricky,
Sorry the LOOP_GAIN plot has not same axis for both PHASE and Gain so I have attached the same with same axis in GAIN and PHASE
raja.cedt
Reply #6 - Apr 30th, 2012, 1:53am
@buddy: hello buddy..i couldn't understand this "According to the slope of the magnitude response at unity gain the phase margin should me much lower". could you please explain how to estimate phase margin from the slope?
@ ricky: in theory you get small overshoot (around 3%), but when you implement with transistors you could expect slight change in the gm or some small signal parameter, and may be your overdrive of the input pair lower and with 30mv swing it may change some %ge. So try to apply very small step like micro volts or increase the transistor overdrive.
From your step response i can imagine there is a RHZ..but why it is not in magnitude plot?
raj.
buddypoor
Bremen, Germany
Reply #7 - Apr 30th, 2012, 3:13am
@ricky: Sorry, I didn't see the phase (forgot to scroll). Please, can you confirm that you have used the "double-injection technique" ? (Because the term "Middlebrook" is somewhat ambigious).
@raja: In most cases (in particular for opamps without transfer function zeros and with a continuous gain decrease) the phase response is directly related to the gain response and, thus, must not be shown explicitely. In these cases, the phase margin can be estimated using the SLOPE of the gain function only. In particular, if the 2nd pole is approx. at the unity gain frequency (slope changes from -20 to -40 dB/dec) the PM will be approx. 40...50 deg.
Ricky Chen
Reply #8 - Apr 30th, 2012, 3:44am
buddypoor wrote on Apr 30th, 2012, 3:13am:
1:- Middle-Brook theorem is NOT ambiguous at all.
2:- Yes it is 'double injection technique' i.e. I found RRi(injecting current) and RRv( injecting voltage) at the break point.
This is clear from the schematic I have shown.
3:- From gain plot it is very difficult to figure the PHASE AMrgin.
As it may have pole zero pairs.
Ricky Chen
Reply #9 - Apr 30th, 2012, 3:48am
raja.cedt wrote on Apr 30th, 2012, 1:53am:
raj.
1:- Why you imagine RHZ from transient response ? Can you tell the reason behind it ?
2:- Do you expect a peaking in Magnitude plot to reflect RHZ ?
Ricky Chen
Reply #10 - Apr 30th, 2012, 3:57am
Dear Buddy,
Why you are deriving that the 2nd pole is near UGB of the Loop-Gain ?
If you carefully look at the Gain plot,  the 2nd pole is around 1.38 GHz which is 2.3 times than the Unity LOOP Gain frequency 613MHz.
I guess 2.3 times can easily give you  66 degree PM.
Please NOTE the axis is Logarithmic !!
Ricky Chen
Reply #11 - Apr 30th, 2012, 4:14am
[quote author=raja.cedt link=1335730561/0#6 date=1335775995]@buddy: hello buddy..i couldn't understand this
I actually did with 1uV input. No peaking is SHOWN.
I wonder why you tell that transistor is overdriven.
Pleas NOTE:- The input is being applied at the input-R of the OTA not at the OTA input. ( please see the schematic). Also the OTA's o/p stage is a CLASS-AB so slew is NOT that a problem  and feed-back makes the input of the OTA stand-still(virtual Ground).
raja.cedt
Reply #12 - Apr 30th, 2012, 4:17am
hello ricky,
when you have RHZ step response starts in opposite direction. As you can see in your step response first started in -ve direction and it entered into +ve direction.
raj.
buddypoor
Bremen, Germany
Reply #13 - Apr 30th, 2012, 6:13am
I wrote that the TERM "Middlebrook" is not sufficient because his theorem (The general feedback theorem, GFT) consists of several parts (some with simplifications).
But it was not clear from the drawing - more than that, I must apologize for not beeing familiar with your simulation program (incl. schematic entry).
May answer to raja was a general one and not specifically related to your drawing.
buddypoor
Bremen, Germany
Reply #14 - Apr 30th, 2012, 6:16am
As mentioned before, my statement regarding the UGB was part of my answer to raja and not in response to your drawing.
Pages: 1 2
