Jul 31st, 2024, 3:20am
Pages: 1 2
No Peaking with Transient Response with PM of 66 degre (Read 9647 times)
Ricky Chen
Re: No Peaking with Transient Response with PM of 66 degre
Reply #15 - Apr 30th, 2012, 7:29am
raja.cedt wrote on Apr 30th, 2012, 4:17am:
hello ricky,
when you have RHZ step response starts in opposite direction. As you can see in your step response first started in -ve direction and it entered into +ve direction.
raj.
Dear Raj,
Thanks a lot for pointing the very important point.
In the schematic there is a 8pF cap between in and OUT of the OTA.
So this is probably creating a feed-forward path and hence RHZ.
When I removed this cap I didn't get any reverse direction movement in the transient.
Again thanks a lot for pointing this.
Kind Regards,
Ricky
Ricky Chen
Reply #16 - Apr 30th, 2012, 7:34am
buddypoor wrote on Apr 29th, 2012, 11:08pm:
Hi Ricky,
2.) Are you sure that the loop gain was simulated correctly? According to the slope of the magnitude response at unity gain the phase margin should me much lower (perhaps 45-50 deg).
You have mentioned here that the PM shouldn't be much higher from 45 degree. I guess you have thought the 2nd pole is very close to the Unit loop gain.
This actually baffled and scared me about my design and simulation method
raja.cedt
Reply #17 - Apr 30th, 2012, 8:54am
hello rycky,
i forgot to mention some thing..when you have 67deg phase margin step response slope at t=0 will be lesser than first order and in theory you get 0. But your slope is very, for me it gives first order feeling.
Raj.
Pages: 1 2
