raja.cedt wrote on Apr 30th, 2012, 4:17am:hello ricky,
when you have RHZ step response starts in opposite direction. As you can see in your step response first started in -ve direction and it entered into +ve direction.
raj.
Dear Raj,
Thanks a lot for pointing the very important point.
In the schematic there is a 8pF cap between in and OUT of the OTA.
So this is probably creating a feed-forward path and hence RHZ.
When I removed this cap I didn't get any reverse direction movement in the transient.
Again thanks a lot for pointing this.
Kind Regards,
Ricky
